We are hearing reports that DIRECTV recently changed the toll-free number that TiVos are supposed to use when first dialing in. This first call gets a list of local dial-in numbers. If the TiVo doesn't dial the correct number, you often will see the message, "Service Not Answering," although the error could be different depending on your phone setup.
Here is the solution to this problem:
As the dialing prefix in your TiVo's dialing settings, enter the following:
,#096,,XXXXXXXXXX
comma=pause on your remote
#=enter on your remote
Replace the Xs with the local phone number you want your TiVo to dial, as you would dial it on your phone. You can get the local number here:
http://www.tivo.com/findanumber
Note that it can sometimes take many tries to dial in successfully, depending on your phone setup. If you continue to have trouble dialing in, here is more phone troubleshooting assistance:
Phone help
,#096,,XXXXXXXXXX
Phone help
