Upgrade drive size
  • Upgrade drive size
    I am trying to upgrade my dual tuner TIVOdt649080 to a larger hard drive. I have a Seagate 300 Gig drive. My original drive (80 gig) that came with the TIVO works great, I just want a larger drive. When I restore to the new 300 Gig drive, I only get 147 hours of capacity, about half of what I should get with a 300 Gig drive. Any thoughts on the problem?
    Sounds like you may have left out the "x" in your restore command.
    That's all there is to it!
      Thanks for the reply. The restore command I am using containes "-xzpi" and i have been replacing the "z" in the command with the drive letter for the target (new) drive. Is that correct or should i use the command with the "z" in it as is?
      Lou
        That's an error, actually.
        Code:
        -xzpi
        should be entered as it appears above, with no substitutions.
          I tried it again with "-xzpi" entered and still had the same result. Here is the string as i enter it where "^" is a space:
          mfsbackup^-f^9999^-so^-^/dev/hdd^|^mfsrestore^-s^127^-r^4^-xzpi^-^/dev/hdb
          The old TIVO drive is the seconday slave and the new Tivo is the Primary slave. I must have somehting wrong. The BIOS sees all 300 gig.
          Lou
            The problem is likely that you are in the wrong Linux kernel. You are in an older version of Linux that only supports up to 137 GB of space per drive, so you got cut off there.
              Thank you. that sounds like the problem. Any suggestions where I can get a newer version of Linux?
              Thanks again.
              Lou
                I am using the version mfstools2.iso I downloaded from http://hellcat.tyger.org/MFS/2.0/.
                  OK - that's likely the floppy. Try our file from the file area here:
