Problems Upgrading HR10-250 with Dual 500GB Drives...
  • Problems Upgrading HR10-250 with Dual 500GB Drives...
    Guys,
    I am having a problem using the Interactive TiVo Upgrade Instructions to upgrade a standard 250GB HR10-250 w/ 6.3a to dual 500GB drives. I am using an LBA48 boot disk and this is the command I have been trying.
    mfsbackup -f 9999 -so - /dev/hda | mfsrestore -s 127 -r 4 -xzpi - /dev/hdc /dev/hdd
    I am able to boot the drive boot it keeps green screening when I do a clear and delete everything. I tried upping the swap size to 500 and that doesn't seem to work either. Is there something I am missing here? I have done this on another HR10-250 with dual 500GB and I somehow got it to work, but that was 6 months ago. I also tried doing a single backup and then using mfsadd but it reboots once I get to the almost there screen. Do you need -r 4 when using mfsadd? Do you need to have a bigger swap for dual 500 drives?
    Y2J
    For an update I am getting the following error after using the above command:
    mfs_load_zone_map: Primary zone map corrupt, loading backup
      Sounds like your 250 is bad or going bad. Have you tested it? Do you have a backup image?
      For a variety of reasons, the swap size you've specified is totally fine.
