Hindsdale - Copied not expanded - Live TV Reboot
  • Hindsdale - Copied not expanded - Live TV Reboot
    I have an RCA DVR40 that had the hard drive going bad. Stuttering & pixellation, rebooting. I am replacing the 40Gb Maxtor Fireball 3 with a Seagate 120Gb Barracuda.
    I performed the Hindsdale copy/restore and I am currently checking the test image. It boots and I can run thru menus, see system info and check satellite connection levels but when I flip to Live TV it reboots the system after a few seconds < 10s. HardDrive is set to CS, same as the Maxtor was. Master didn't give me menu access it went directly to live TV and rebooted.
    Should I perform the capacity upgrade and see what happens? Or is this a bigger problem? If I exapand the capacity what are the steps to redo the Hindsdale process. Do I need to format the Seagate or will it overwrite?
    Thanks in advance for any help anyone can provide. I'm a newbie trying to get my, too many hours, of TV watching back.
    Probably you've copied a corrupted version of the TiVo OS over to the new drive. We can prep the drive for you if you'd like - more info is here.
      Thanks for the info. I appreciate the reponse.
