I added a second drive with the Hindsdale kit (to a Hughes HDVR2 Tivo). It's hanging on the "powering up" screen. (How long is typical on this screen? I did trying waiting for a few hours but no luck...). I've tried taking everything apart, reseating everything including the jumper on the master disk.
The instructions say the jumper for the master disk goes on the far left set of vertical pins (I have 4 vertical sets, its a Maxtor drive). I assume that's right; it was prior to adding the 2nd disk on one of the middle two (I forget which, but I may try moving it back and disconnecting the new drive just to get the thing working again).
All power cables are definitely hooked up and seated, and the IDE cables are definitely hooked up right and seated.
Any suggestions? The directions said to not touch the jumpers on the new disk, and I haven't, but how should they be so I can check them just to be sure they were set wrong from "the factory"?
Frustrating to spend several hundred and get...a non-booting Tivo!
-Kevin
-Kevin
