I bought a first generation TiVo DirecTV HR10-250. Is there a way to tell from the outside or menu what it has inside, and how large can they be made today with upgrades?
DirecTV HR10-250 upgrade to ??
You system information screen should tell you what the recording capacity of that particular unit is; a function of the drive size installed within.
As for how large you can go, about 200 HD/1300 SD is currently the max. Some drive options weaKnees offers are here:
http://www.weaknees.com/hughes-hr10-250.phpThat's all there is to it!
Yes, you can send analog signal to your dvd recorder in order to burn contents to disc.
A for connecting your Samsung SP-P4251 (is that a TV?), you might need to use either a component cable or an HDMI-DVI cable. Not sure if that model TV has HDMI input.That's all there is to it!
