I have just installed an SWM-8 with an 8-way splitter on a 5 LNB slimline. I currently have only 3 receivers hooked up, but got an 8-way splitter for near future expansion. Current set-up: HD-DVR HR22-100, HD H21-200, and a standard D 12-100.
After the initial install I was only receiving a few channels. I did a reset on the DVR receiver and then could not get a signal at all. Check other HD receiver and still had the few channels I had initially on DVR receiver. Rechecked all connections (inside and out) and everything seemed fine. The SWM in this initial try was approx. 45-50 ft away from the dish, so I then decided to disconnect and retry directly at the dish.
All 4 cables attached to SWM at dish with the power supply and splitter about 50 ft away in the basement. The cable run from the splitter to the DVR is 25-30 ft. Did set-up from DVR and got the same results as with the initial try.
Also, when I did a signal strength check it shows the SWM along with other satellites. My question here is will the SWM show up if it is malfunctioning and/or will it show up just because I changed the switch type in the satellite dish set-up menu?
It seems like I have installed everything correctly but of course I am a newbie to this stuff and I may have missed something. The house is only 5 years old and the DirecTV was installed 2 years ago and uses RG6 coax.
Please help!
Please help!
