I want to replace my RV's ancient RCA DRD486RH DTV receiver with a new R22 dual tuner receiver/DVR.
The RV installation has a KVH TracVision S2 satellite antenna with dual LNBs; but only a single satellite drop cable from one of the LNBs to the DTV receiver.
Will the following configuration work?
At the dish:
1. Connect each one of the KVH LNBs to a separate Sat 99/101 port on an SWM-8.
2. Ignore (cap-cover) all other (unused) inputs. (Probably good practice to cover unused outputs, as well).
3. Connect the existing satellite drop cable to the SWM1/PWR connector.
At the receiver location:
4. Connect the existing satellite drop cable to the SWM port of a PI-28 Power Inserter.
5. Connect the IRD port of the PI-28 Power Inserter to the SAT-1(SWM-2) satellite input connector of the R22 receiver/DVR.
Will the SWM hardware/firmware of the SWM-8 and R22 systems be able to successfully self-configure to ignore the missing LNB feeds and tune the same channels as the old DTV receiver (101 satellite)?
Are there any other steps/procedures that are needed to make this a successful installation?
If the above connection scheme is workable, then would the addition of a 1x2 SWM splitter allow the use of a second DTV receiver for the RV's bedroom TV?
Using the SWM-8 may be overkill for this application, but it would be an easier and perhaps less expensive solution than running a second cable and re-sealing the RV's roof.
Thanks for considering my questions,
slotraveler
At the dish:
slotraveler
