Last week I installed the SWM8 (replacing a Zinwell 6x8 Multiswitch), and have been getting excellent results on the 2 HR-20 receivers that are each connected to a SWM port (power goes to port 1). The three Legacy ports each now feed the following: a D-11 / 100, a D-11 / 50, and an R-15 DVR. The D-11 / 500 was just installed to replace an older Samsung TiVo that wouldn't get a clear picture from the Legacy port after the change of multiswitches (screen filled with horizontal lines over faint image).
The D-11 and R-15 units would work well for a while and then randomly start having short picture freezes (horizontal bars of pixellated video accompanied by high-pitched audio noise). No pattern could be found in this behavior.
I read elsewhere in this forum about a similar problem whose author was advised to check the grounding. My SWM did not come with grounding instructions - where can I find that info?
Also if there are any other possible issues that could affect my troubles, please advise. I am about to call in a specialist if I can't make this work myself.
