I notice the SWM8 site says the SWM will not work with the 3-lnb dishes - it will. Obviously you can't receive signals from the sats at 99/103, but as far as the dish is concerned the SWM8 is just another multiswitch. So if you have a 3-lnb dish you can connect an SWM8 with no problem, and then any SWM-compatible receivers connected to the SWM will have access to the 101/110/119 satellites just as they would if connected directly to the 3-lnb dish. You simply have to make sure that the dish type is set to 3-lnb.
There is even no technical reason why the SWM won't work with a round dish. You just connect the two cables from the dish to the 99/101 13v and 18v connectors on the SWM and then tell the receiver it's a round dish.
