I have just purchased a used HD 10-250 to replace a HDVR2. I added a 500gb hard drive from Weeknee's and everything is working fine except I cannot locate the off-air Channel Settings to confirm or modify these settings.
Some background, I am adding all of my season passes to the newly purchased HD 10-250, using a EXT 2 input on the TV, while continuing to use the HDVR2 as my primary receiver until I have everything up and running on the HD 10-250. I move the satellite input connections when the "Todo list" is idle which is generally late in the evening. My Directv subscription includes local channels for my area.
I am connected the new HD to an off-air antenna but I am unable to view local stations once the satellite connection is terminated.
I have tried to "scan for off-air channels but I cannot locate that screen. Messages & Set-up > Setup is all I can toggle to. I have tried to "repeat Guided Setup" by pressing 3 THUMBS then ENTER but nothing happens.
Apparently, I need to start fresh but I am even unable to RESTART or RESET SYSTEM.
Does anyone have any suggestions, I am very perplexed and at my wits end!!!!
Thanks to all in the Community
charlie
charlie
