I have DirectTV. I have 3 regular receivers hooked up and 1 hd DVR. I have had different Direct TV installers here to work on problems and seem to get different answers from all of them.
The current configuration has the cable coming in from the SWM to a 4 way splitter. The cable running to my DVR has a PL-21 power inverter hooked up.
With the power inverter in line, I keep loosing my signal coming in to the DVR. The other three tv's seem to work fine. If I pull the inverter out of the line, and run the cable direct to the DVR it appears I get a good signal.
Questions:
1. What does the power inverter actually do?
2. What if it isn't in line? Do I lose quality? DVR capabilites? signal strength?
3. Is there a way to check to see if the power inserter is actually working right?
Thanks for any help.
Questions:
