This can be a confounding issue, but usually the cause for a missed recording amounts either to simple scheduling conflicts or a mis-set preference in your Season Pass. Here are a few things to check and/or try...
1 - Prioritize! Go to your Season Pass list and arrange it from top to bottom in order of most to least important. (When you park on a show title, arrows should appear beside it. Move over to the arrows, then cursor up or down to change the order of the show.) A higher priority show will cause a lower priority show in the same time slot to get skipped. Here's a useful link that relates to arranging your Season Pass list:
http://www.weaknees.com/seasonpass/
2 - Depending on your preference, make sure each specific Season Pass is set to record either first run only, repeats, too, or all episodes (meaning every time the show comes on, including duplicates).
3 - Also make sure to set the number of episodes you wish the TiVo to keep on hand and how long the TiVo should keep them.
4 - Make certain you have enough space. Remember that your TiVo's recording capacity at basic quality correlates to only about a quarter of that amount at best quality (that's for Standalone users...Directv TiVos only have one quality setting). It could be that your TiVo has run out of room and you have set all of your current shows to "Keep Until I Delete."
5 - Sometimes a future episode is on a different channel than the one for which you've set your Season Pass. Either make a separate Season Pass for these showings, or create a Wishlist for that specific show title.
6 - It's possible your TiVo has run out of Guide Data. Make sure you TiVo's modem is working and that you have at least 2 weeks worth of show schedules. If the TiVo doesn't know a shows on, it obviously can't record it.
Hope these suggestions help. But if there's something I'm leaving out, but sure to let me know.
-Jason
-Jason
