When the networks all make the Big Switch to broadcasting everything in HD, what happens with Series2 (and Series1) TiVos Will they be able to record HD signals Will they need to be hooked up to a converter
Series2 TiVos when the HDTV switch over happens?
Michael,
Can you be more specific with you comment, "you shouldn't have any issue."
I currently get basic cable (no box) through Time Warner. I am considering purchasing 2 Series 2 Tivo boxes (one 80hr and one at least 300hr). I intend to make extensive use of the Multi-Room Viewing feature over a wired LAN. I don't intend to make the switch to HD (do I really need to see "Dirty Jobs" in all it's gory detail?) any time in the next couple of years.
Any recommendations or suggestions would sure be appreciated.
Thank you,
Steve
Originally posted by WK-Michael View PostThat's really not what's happening. They're moving to digital, but not necessarily HD. If you use antenna right now, you'll need a converter.
Will the Tivo be able to change channels on these converter boxes? Will the programming guide still work and record properly with the digital conversion box?
Originally posted by pueo View PostWill the Tivo be able to change channels on these converter boxes? Will the programming guide still work and record properly with the digital conversion box?Last edited by WK-Jason; 08-30-2007, 03:11 PM.That's all there is to it!
