It appears from the setup screen that pairing a new remote erases previous pairings. I would like to have 2 remotes in different locations for the same box. Is this possible?
Can 2 Remotes control same bolt?
I've got a couple questions along the same lines.
I've got a Tivo Bolt. I have the existing white remote that came with it. It works fine. I presume it is an RF remote.
I have a second Tivo located on a different floor, far away from the Bolt. A Premiere XL and the remote that came with it. I am pretty sure the remote is IR.
I am planning on getting a slide remote primarily for use with the Bolt. Can I use both of these remotes (original Bolt remote & new Slide Remote) for the same Tivo Bolt ?
Will I have any functionality on the Premiere with the new Slide remote? IE can I do the same thing on the Premiere? Have BOTH remotes control the premiere?
Originally posted by WK-Michael View PostYes - the white Bolt remote has RF.
The Slide remote can only pair to one TiVo as it is also RF. ...
Thank you for the quick reply.
Can I have the TWO remotes (Bolt and Slide) control the bolt without re-pairing each control each time?
Thank you.
