directivo welcome / almost there / standby loop -- kickstart codes?
  • directivo welcome / almost there / standby loop -- kickstart codes?
    I have an 11 year old Series 2 DIRECTV DVR (SD) RCA DVR80. This evening it got into a boot loop: I get the "welcome. powering up..." screen for several minutes, then the "almost there. just a few minutes more..." screen for several minutes, then a brief flash of the "press directv" screen it usually shows when entering standby (which is the mode I leave it in when I'm not using it) and then back to "welcome" again. It's possible (although I'm not completely sure) that it has recently been showing some minor vertical striping in the video image (by which I mean horizontal variations in brightness). On the "welcome" screen, I'm definitely seeing a diagonal herringbone pattern.
    The hard drive and power supply were replaced about a year ago. It is connected to a UPS. As far as I know there haven't been any power failures, lightning strikes, etc.
    I swapped the hard drive out for its predecessor, which is 9 years old (8 years use followed by 1 year storage). Now it seems to be working (I still see the herringbone).
    So either my relatively new hard drive went bad, or has some bad interaction with some other failing component; or just the process of opening the system up and swapping drives kicked it into working again. (I guess I could swap the drives back and see what happens.)
    I looked at http://www.weaknees.com/tivo-kickstart-codes.php. Do any of those codes apply to a DIRECTV TiVo? If so, perhaps I can put the new drive back and run diagnostics on it.
    I looked at http://www.weaknees.com/repair.php and http://www.weaknees.com/tivo-powering-up.php. Is the cycling I'm seeing (3 screens) the same as the cycling described in the latter URL (2 screens)?
    Yes - you can do a kickstart on your unit. And this does sound like a bad drive, pretty clearly.
    As for the herringbone pattern - electrical interference maybe?
      Just now I powered down the unit (rearranging some equipment) and powered it back up (still using the 9 year old drive). It made it all the way through to live TV. I was able to swap tuners (although one tuner doesn't work). When I hit the menu button, the screen went black. Now I get no video or audio, but the green power light is illuminated, and shows amber when I press buttons on the remote. The fan is running and I'm pretty sure I can feel vibrations from the drive. Pressing the "Power" (standby) button flashes the light amber, but does not seem to put the unit in standby. Is this the sign of a power supply problem? Or something else?
        If you press the DIRECTV button, can you still see the menus?
          No, I can't.
            Strange. I wish I had a certain answer on this one, but I just don't.
            I'd say you should send it in for the flat fee repair for Series2 TiVos:
            http://www.weaknees.com/tff
