TiVo Premiere XL4 - No signal and all lights on the front are lit
  • TiVo Premiere XL4 - No signal and all lights on the front are lit
    I have a TiVo Premiere XL4 (about 3 years old). It was working fine this morning, then when we went to turn on the TV later today, there was no signal. The TiVo Premiere XL4 box has all lights lit up. I have unplugged the power and disconnected and reconnected all the connections in the back and it is still not functioning. Do I need a new power supply?
    Sounds like you do, but on that unit, a bad drive can cause similar symptoms, as can a bad HDMI port.
    Have you tried other video outputs?
      Thanks for your reply. I did try the RGB output and no luck, still all lights on solid. I have ordered the power supply from WeaKnees and I hope that repairs it!
        Bummer. The power supply did not fix it Does that mean I have a bad hard drive?
          Yup - then it's most likely the drive.
