THR22 Startup Problem
  • THR22 Startup Problem
    I have a THR22 and whenever there is a power outage, and often after a restart, it has trouble reacquiring the signal from the SWM unit.* It gets stuck at 5% and will not load.* Eventually I can get it working with a series of disconnecting & reconnecting the power/coax.* I have been unable to determine a set order of connecting items that causes success, but once I get it going it's fine until the next power down/restart.* Any ideas?
    Are you using a SWM system? If so, it's likely just that the SWM is still powering up when the THR22 tries to get a connection initially.
