I have a Premiere XL that's run flawlessly for 3 and half years. Then yesterday displayed GSOD.
1. Going the logical route, I pulled the HDD and ran the WD diagnostics, Quick and Extended Test ran with no errors. After finding the instructions, I ran ddrescue to an identical drive. ddrescue completed with no errors. To me this says my HDD is fine.
2. I installed the cloned drive in the Tivo and with this drive it just enters a reboot loop of 'Welcome...' and 'Almost There...'
3. Started trying the Kickstart codes. 54-Thru short test, says disk is fine. Tried each of 51-Software Upgrade, 56-Software Install and 52-Emergency Software Reinstall. None of these got to the 'Installing Service Udate.' screen.
4. Checked the BIOS Battery.
5. I do have a failing fan. It is still spinning but making lots of noise.
6. Checked P.S. +5.15 and +12.35. Little low but should be ok, I think. (other opinions are welcome.)
7. Re-installed the original drive that tests ok, Ran Kickstart 57 . This morning it was at the GSOD. Now this disk always encounters the GSOD. Does not respond to Kickstart codes.
Although before the GSOD, I was experiencing slight pixelation and studdering in a show I record every day and it was occurring at the same point in the recording (I keep multple episodes so it wasn't likely writing to the same place on the disk). I thought maybe cable was doing it. Also, sometimes when I used the back arrow, I see the preview window but the rest of the screen was black. Had to go to live TV then the TiVo key to get to the menus.
So, before I bite the bullet and buy a replacement disk form WK, is it still possible there is something else or is the HDD is causing? I'm wondering if files on the disk got so whacked that the BIOS can't boot the disk any more. But why doesn't Kickstart 52 work?
John
John
