Tivo HD appears to have multiple problems
  • Tivo HD appears to have multiple problems
    I have a Tivo HD from 2009, upgraded to a 1 TB drive. Last weekend, the Tivo could not get past the welcome screen, rebooting continuously. I pulled the drive and it failed a S.M.A.R.T. test. Since I had the original 160 GB drive that came with it (which theoretically is in near-new condition as it has not been in use), I installed it and now the Tivo will not power on at all - no LEDs, fan does not spin, hard drive does not spin - no indications of life. While I've been tempted to get a new Roamio, I would like to repair this one as well. Is this definitively a power supply issue? I have a volt meter handy - is there any place on the power supply board to check voltages? If I understand your store policy, is it correct that I could buy the power supply and then return it if it doesn't fix the problem?
    Rather than using a voltmeter, just do a visual inspection. See this page:
    http://www.weaknees.com/bps
      No obvious bulging or discolored caps. The only thing that looks funny is that the paper-type material around the "hi-pot" has a brownish color. This appears to be inconclusive... Any ideas on what to try next?
        I don't see any bulging or discolored caps. The only item that has discoloration is the large hi-pot (the papery material surrounding it has a brownish color) - is that the problem?
          That may mean there was some overheating on the power supply.
          But in the meantime, have you run the Kickstart 54 on the old drive?
            If I put the old drive into another Tivo HD, can I run Kickstart 54 on it then? I hadn't run Kickstart 54 on the old drive in the malfunctioning Tivo because it wasn't working for some reason (after it accepted the sequence "54", it rebooted without running the process).
              Sure - that should work.
