Help HD Tivo 652160
  • Help HD Tivo 652160
    My Tivo froze the other day, tried to reboot and it was sticking on almost there screen, I ordered a new hard-drive and when installed it would not move past a black screen and only got a green light on panel, it would flicker every minute or so, but no yellow or red,
    What should I do next, Help
    The flashing green light on a TCD652160 is still not something we can fix, unfortunately. Are you getting a consistent flashing green, or something else?
    What happens if you put your old drive back in?
    EDIT: We can now fix this problem! Please see this blog post:
    TiVoHD with Flashing Green Light
      Same, the green light come on and it flashes yellow once, then goes solid green
        I plugged it back up with old hard-drive this morning, just to double check, and it is back to locking up on almost there screen, green light is solid.
          I think I found your order in our system based on your user name. I'd suggest you look at your order invoice. It looks like you ordered a drive for at TCD648250, which will not work in your model TiVo.
          You might want to return that (I will email return instructions to you now) and order a drive here:
          www.weaknees.com/s316.php
