Hello Everyone,
I bought a Toshiba SD-H400 off eBay last week and its running great. It has an upgraded 300 GB hard drive. I have a few questions though the unit seems sort of loud. I can hear the hard drive or what I'm assuming to be the hard drive when the T.V. is off. Is this normal? My other issue is when I try to put the unit into standby it goes into standby mode. When I try to take it out of stand by mode I can hear audio but I only get a blank screen. The only way to fix this is to restart the unit by unplugging it. Any thoughts?
Also the Tivo is hooked into my cable box via the white,yellow and red cable. the Tivo is hooked into my T.V. using another set of white.yellow, and red.
Thank you
Thank you
