The other day I was in a hurry after work and carelessly kicked off my workboot which flew and hit the tivo box. Since then I have the classic dead hard drive symptoms, if I am watching a recording it will self pause with no ability to control the tivo with the remote, then it reboots. Also, I had a recorded show paused for few minutes when suddenly it rebooted as well. I am currently running kickstart 54 and have passed the first 3 tests, it is running extended test now.
Did I bump something loose inside the tivo? Or did the harddrive "needle scratch across the record" and now I have a corrupt drive?
Should I take apart the unit and see if connector came loose?
I will also look at the capacitors when the box is open, but I looked at the pictures of bad capacitors on this site and I only see 1 picture that shows a bad capacitor the other two I dont see whats being shown, is it the white foam stuff I see? Thx in advance all
