Each TiVo can be uniquely addressed in the system information screen so that it will only respond to a specific remote control. Up to 10 TiVos can be addressed this way. Below are instructions for setting up your first two TiVos with separate remotes...
1 Cover the IR window of the TiVo #2. Do this well or TiVo #2 will get programmed at the same time.
2 Pick up remote control #1 and navigate TiVo #1 for to the System Information screen. (Messages & Settings: System Information). Scroll down with the Channel button until you see the Remote Address.
3 Hold down the PAUSE and TiVo buttons for 5 seconds. Let go when the red light on the remote turns solid.
4 Using the number buttons on the remote 1-9 (1-3 on a Sony), select and press a single number to assign the first TiVo. (For eaxmple, 1) The remote light will flash, but the screen information will not change yet.
5 Press the RIGHT arrow. The Remote Address on the TiVo screen should now show the new TiVo number.
Phew! Halfway there...
6 Press the TiVo button to return to TiVo Central.
7 Carefully cover the IR window TiVo #1 and uncover the TiVo #2. Pick up remote control #2.
8 Hold down the PAUSE and TiVo buttons for 5 seconds. Let go when the red light on the remote turns solid.
9 Using the number buttons on the remote 1-9 (1-3 on a Sony), select and press a DIFFERENT single number to assign the second TiVo. (How about 2?) The remote light will flash, but the screen information will not change yet.
10 Press the RIGHT arrow. The Remote Address on the TiVo screen should now show the new TiVo number.
Press the TiVo button...your TiVos are now programmed to respond only to their assigned remotes.
