Bolt in startup loop - Not drive or power supply
  • Bolt in startup loop - Not drive or power supply
    I've got an OTA Bolt that will not boot, it constantly reboots during startup. I tried a different power supply same behavior. Also tried a new drive from Weaknees, also same result. Curious as to what could be wrong with it, and can you repair it if I send it in?
    How about a different power outlet or omitting a surge strip or splitter? With two drives and two power supplies, this sounds like an external power issue.
    Also try booting with only the HDMI and power cables attached.
      Did all that before trying the Weaknees replacement drive. I feel it's something on the mainboard. I assume you don't repair boards and swap them out.
      How much would that cost?
        We don't have motherboards for swaps.
        Overall, pretty strange that a new power supply and drive didn't fix that.
