Pausing and Pixelating on Roamio
  • WK-Michael
    replied
    OK - that's a tuning adapter, so that makes sense. I was thinking you were talking about a typical cable box that has the normal channel selection features.
    Leave a comment:
  • Gregavi
    replied
    Not sure what you mean. I have a Cisco cable box connected to my Roamio Pro via coax cable. Standard connection. It also has a USB connection from cable box to Roamio.
    Leave a comment:
  • WK-Michael
    replied
    How can it be connected to your cable box? Roamios just don't work like that.
    If you want to test your drive, do this:
    https://www.weaknees.com/54
    Leave a comment:
  • Gregavi
    started a topic Pausing and Pixelating on Roamio
    Hi, I have a Roamio connected to cable box. When I watched recorded programming I am getting pausing with pixelation during playback. If I scan foward it skips through it. If I rewind and play the same section again it behaves the same way. This started several weeks ago and it is happening more and more. My signal strength is 98% and my SNR is 39 db.
    Is it possible my hard drive is failing or is it likely some other issue? Thanks in advance.
