Will a HD Tivo unit work with an SD TV? We have 2 TVs, and one is analog SD made in 2004 with no digital option, so we use an analog-to-digital converter(or is it the other way around). Up to a few weeks ago had Direct TV. I also have use an older SD Tivo Unit with our SD TV for years, ordering parts from Weaknees when needed. Have converted to antenna, but notice that all units are HD. Will an HD Tivo recorder work with an SD TV? Thanks.
Just switched to antenna with SD TV set
Well, they'll work, but the newest units only have HD outputs.
We do sell an HD to SD converter that you could use to couple a Bolt, for example, with your SD TV:
https://www.weaknees.com/hdmi-to-old-tv-converter.phpBeen here a long time . . .
