Think your tivo hard drive is dead? Here's how to find out...
This is a sticky topic.
Not only would it not be readable in a Windows OS, the boot CD really can't access a network.
Well I'm not sure I want to risk trashing the existing drive..
Then again I might just be able to plug it into the PC and make a backup of the entire drive to the homeserver.. That would give me a fallback if the process fails. Provided it's in a format that can be read by windows OS, if not that idea might be a no-go
guess I need to go read up on making the required bootable CD's the PC is running windows7 and all the drives are NTFS
So I take it the drives are like some kind of stripe set? I can't just replace the primary drive with the new one and leave the old second drive in system?
Leave a comment:
The new 500 GB drive came with a SATA adapter, so that gives you two ATA ports in your PC essentially. If the unit doesn't boot, you'll have a hard time copying data, but you can try. More info is here:
The problem, of course, is that if you aren't successful, then you've overwritten the OS on the destination drive, and then IT won't boot . . .
Leave a comment:
I have an Directv-TIVO RCA 40 gb, purchased from Weaknees with installed 214 hour capacity (dual drives I think)
System has started to randomly hang, sometimes while 'off' other times in middle of viewing. With a few exceptions where more than 1 try was needed, just doing a power plug out--in reboot got it working again
Surmised it must be a bad drive, order single 500G replacement from Weaknees and it arrived today.
Trying to do a kickstart54 to get an idea which drive is bad, after holding pause during reboot I eventualy get both front LED's turning yellow, after 54 code entered left led goes green, right stays yellow, but nothing seems to happen, I still have the Welcome. Powering up logo
The real question is, is there a chance to save the old programming on the existing drive(s) and transfer to the new drive?? If so, does that mean I need all three plus a cdrom hooked to the computer at once? (which would be difficult since my new system has sata connectors galore, but only a single IDE (ATA) connector.
Leave a comment:
Just wanted to stop in and say thank you. This thread helped my 65 year old mother diagnose the problem with her TiVo.
She ordered a new drive, it arrived quicker than we thought, so she replaced it on her own following the great instructions. No problems at all and she is back watching TiVo which she much prefers to "that crazy TV with all the channels and ads!"
Leave a comment:
Sounds like you need a new drive, and that data recovery is unlikely. Sorry.
Leave a comment:
Hard Drive Dead?
Hello,
My series 2 Tivo is stuck on the grey powering up screen.
I tried unplugging the input and then the power as the tivo tech suggested... but when I replugged in the power there was no improvement.
I'm thinking my harddrive is pretty much dead...
Do I need to get a replacement Harddrive since I can't interface with the tivo?
I was hoping there was a chance to recover my programming and get an add on... but that is probably wishful thinking...
What do you think?
Leave a comment:
Yup - I'd say that's almost definitely a bad drive. Find your model here:
Leave a comment:
Sunshine screen...
We had two electrical storms last night.
The Tivo was in the middle of rebooting when the power went out with the second storm.
Now it will only boot as far as the "sunshine" screen that says "Welcome" and will sit there as long as it is plugged in.
Suggestions? (Please let it be a hard drive problem... we just bought the lifetime service last year! Waaa!)
Leave a comment:
Replacing a hard drive in a TiVo does not invalidate or impact your lifetime service; that is tied to the serial number of the TiVo, which is unrelated to the hard drive.
Leave a comment:
drive replacement question
If I order one of your replacement drives is my TiVo lifetime service still going to be good on the box?
Leave a comment:
Originally posted by elee3 View PostI have a Hughes DVR40 and an RCA DVR40. One of them has a bad hard drive. Everything inside the cases looks exactly the same, but when I tried to swap hard drives I got a hardware error message. I tried to "clear and delete everything", but that went on for 1 1/2 hours. So, should these hard drives be interchangeable?
Leave a comment:
Leave a comment:
Leave a comment:
