Tivo audio out on when play revision 3 hd nation
  • Tivo audio out on when play revision 3 hd nation
    I have a pioneer h810 with dvd. Some times when I play Hd nation a program that tivo donloads from the internet the audio cuts out on the tivo. I have to restart the tivo to get the audio back. Any one have this problem? is there a fix? Is ther a way to get the audio back without restart?
    Thanks in advance for your help or comments.
    Haven't seen that - it only happens with those downloads? Do you download other shows?
      I dont kow it it happens with other content I only download the revision 3 shows. it happens when you start to play the show. I dont know how to fix it other thant to restart. Do you think this is a power supply? I found another post that had the same issue. The person that had the problem never posted if the power supply fix it. Do you know? is there a way to test the power supply? I have a meter. see the post just under this one.
        We have seen audio problems get solved by new power supplies, but no testing of those bad power supplies has helped us figure out where the problem was, I'm sorry to say. I haven't seen this problem get solved by a power supply on a Pioneer TiVo, but then again, I've never seen this problem. I guess it's worth a shot, but I don't have any idea if it's likely to solve the problem.
          thats funny i have the same problem with audio on my roku box! but my tivo premiere xl plays revision 3 channel HD NATION just fine!
            So maybe it's the stream?
