Reboot Loop After Drive Replacement
  • Reboot Loop After Drive Replacement
    Hello!
    I am trying to swap out my failing Maxtor IDE 250gb drive in my Humax T2500 series 2 Tivo, with a new Western Digital 500gb SATA drive.
    I've used the weaKnees cloning/backup utility and am able to do the cloning and/or new installation (with Instant Cake).
    I am using the SATA to IDE cable and coverter I purchased from weaKnees, and when I try cloning to a smaller SATA drive, everything seems to work. But when the 500gb drive is installed in the Tivo, I get an endless power-up loop and never see the "...almost there..." part of the boot-up process.
    The Maxtor is an original drive, Maxline II 250gb ATA 133.
    The Western Digital is WD5000AADS 500gb green drive.
    Thank you!
    You probably need a new IDE cable from us as well.
      I did Order a cable from you as well.
      Nice thinking buy splitting the cable! I used to do that on old gaming PC's.
      So then What could it be?
      Thank you for your quick response.
      Here is my Order id: #710760
        Could be a bad unit, bad hard drive, bad software....just about anything.
          I am able to install a Seagate 250 gb 2.5 inch sata drive and it works without a problem (using the weaKnees Cable and adapter),I go through the entire tivo update regiment. I am able to record shows and play them back every thing works. I have also installed Windows and Kubuntu Linux On the 500 gb Western Digital Drive that I am Trying to use in my Tivo. Both OS's had no issues both Installations and all the updates no problem. I ran western digitals,Data Lifeguard Diagnostic for Windows, What could it possibly be?
          Thanks!
            We'd still guess it's the hard drive. Often, they test fine, but they just don't work in TiVos. Especially WDs.
              Thank you for your help.
