I have a DSR-704 that I expanded a while back. Everything was good until the tuner started going out. My thought was to get a used unit (Got RCA DVR40) and clean the programming, then copy everything from that drive to a bigger drive. I powered up the new unit, it looked OK, so I did a clear all settings. I let it run several hours, and it didn't finish. I rebooted, and it goes directly to that screen. It's been running for 6 hours with the red light going on and off every second or so. I thought it was only supposed to last an hour.
Looks like I can't use my other drive since it is a different model. I didn't mind losing the programming, but I've read that it won't work. Any ideas?
Thanks, Dennis_H
Thanks, Dennis_H
