Rebooting Directv Tivo after Weaknees Repair
  • Rebooting Directv Tivo after Weaknees Repair
    I'm rebooting my old DirectTV Tivo after a repair and it is stuck on the Satellite Dish Guided Set-Up on the screen that says "Checking the Satellite Dish Set-Up based on your dish type" and it stuck "detecting satellites" at 28%. The signal strength is strong on 90 and 91 on each of the the two lines. Any ideas?
    DirecTV solved the problem after 45 minutes of trying. If you ever have the same problem save 45 minutes by unplugging the satellite in cables during the Guided Set-Up and choose fix this problem later at the error message and it will bypass this step. They then had to reset my signal to get local channels to work again.
      FYI, that's in our instructions for the affected models, and also here:
      http://www.weaknees.com/directv_problems.php
