My Tivo S3 can show live TV stations, and the Info and Guide functions work. But when I push the TIVO menu button, I get a half-second of visible menu and then the screen goes all weird horizonal lines, and I can't access programs I've recorded, or the reset functions. I have rebooted the S3 three times with no improvement.
I had the S3 working with my 32" Sony Bravia digital tv because my old 36" SD tv was broken. When the repairman fixed the 36" set, he hooked the S3 to that set. At first the menu function worked with cable. But after the repairman had left, when I screwed in the cable for the separate antenna, the menu was illegible when I tried to set the S3 to work with both cable and antenna. The other inputs to this tv work fine--the problem isn't with the tv set, and this antenna worked fine with the 32" set.
The other weirdness is that I can play randomly-selected recorded programs. When I push the Tivo menu button and then push Select repeatedly, it goes to the recorded programs and plays whatever it lands on. The recorded programs, in other words, are fine--only the menu access is illegible so the machine is really not usable.
Has anyone had this happen, and is there a way to fix it?
John T. Sapienza, Jr.
301-622-1928
SN 3QD0J844
301-622-1928
SN 3QD0J844
