I have a new Tivo Bolt connected through Verizon Fios using a cable card and a Gateway router. Works great. I'm trying to add a new Mini in another room. The new Mini is plugged into coax coming through the wall. I've connected the Bolt to the Gateway router with an ethernet connection and redid the setup on the Bolt as "ethernet". I'm told that the Moca capabilities are all included in the Bolt and Gateway router. When I go through the Mini setup, the Tivo screens show up and the set up process is normal. However, ultimately no live TV loads. Any idea what I might be doing wrong?
Ultimately, is it just too complicated to try to use a Mini without an Ethernet connection? Should I just get a second Bolt box?
