I did a brief search of this forum but did not see any HR10-250 threads that described this problem.
I've had a recurring problem with my HR10-250 (w/upgraded disk purchased through this site) I've noticed recently when using a cheap, indoor/unidirectional "rabbit ear" hi-def antenna. I have two satellite inputs and this OTA input hooked up.
On multiple occasions, I have been watching a local OTA channel (HD) and attempted to do something via remote (bring up the on-screen guide, change channels, flip to the other tuner, etc.)
I can see the "REC" light on the front of the unit go from green to amber when I press a remote button so it appears the unit received the infrared signal(?). But the unit does not respond. Then I will go over and try the control buttons on the front panel of the unit. Still nothing.
Resetting/unplugging the unit will generally clear the problem. I'm just sick of having to do this every time this happens given how long the unit takes to reboot and reacquire the satellite signal.
I have only noticed this problem when I am tuned to an off-air channel, and it only seems to occur if I've been tuned in for a while (e.g., 10 or more minutes) before attempting to issue a remote control command again.
Are there any known software issues which might explain this behavior? The System Information screen says I'm running 6.3d-01-2-357 software version.
