Our Hughes Tivo DVR when in standby mode after some random period of time goes into "limbo" where it fails to respond to the remote control and the front panel buttons. I have to remove the power cord which forces it to reboot. After the reboot it works while it is in the active mode. When placed in standby, some unknown time later it does not respond. Any reason for this failure? Any suggestions for a solution?
Series2 remote control and front panel failure
Sounds to me like your hard drive is locking up, and if the TiVo happens to be in Standby mode at the time, that's where it locks up. Drive replacements are here:
https://www.weaknees.com/tivo-upgrade.phpThat's all there is to it!
Originally posted by WK-Michael View PostStandby is really just 'no video output.' If you leave it on, does it eventually freeze?
Putting the unit in standby really just halts the output of video & audio, but the unit TiVo is still recording in the background. Unlikely that going to standby will have any effect, but it's a good habit to get into, to keep the unit from suddenly outputting sound through a stereo system when the television is off.That's all there is to it!
Originally posted by WK-Jason View PostSounds to me like your hard drive is locking up, and if the TiVo happens to be in Standby mode at the time, that's where it locks up.[/url]
I'm not sure what you mean by "still active in memory" but if the unit is locked up, it's locked up, regardless of what screen it's parked on. Responsiveness to remote commands or the front panel is directly related to the hard drive.That's all there is to it!
Originally posted by WK-Jason View PostI'm not sure what you mean by "still active in memory" but if the unit is locked up, it's locked up, regardless of what screen it's parked on. Responsiveness to remote commands or the front panel is directly related to the hard drive.
Originally posted by WK-Michael View PostThat's just not the way that these work at all, sorry to say. The hard drive is constantly used in a TiVo and if it loses access to write it's current buffer, it dies.
In a dual drive config, either drive could be causing the failure so if you want to test and format them yourself, you'll need to a) run diagnostics on both drives:
then b) replace and/or reformat whatever you wish to put back into the TiVo:
http://tivo.upgrade-instructions.com/index.phpThat's all there is to it!
