I've had a Roamio Plus on FIOS ever since the Roamio came out (so 8 years or so) and it is still chugging along nicely except for a nagging signal drop-off on a couple of channels that is most likely a FIOS issue.
I'm contemplating an Edge (probably for no good reason) but I'm using 4 older Minis (and have MiniVox that I haven't yet used).
Can I continue to use the old minis (I'm still using the original layout) with the Edge? I know the MiniVox is backwards compatible, but I don't know if the old minis (a mix of 92s and 93's) will play nicely with the Edge.
Finally, just for a sanity check, does it make sense to go from a Roamio Plus to an Edge - both would have Lifetime service.
