Dear Weaknees,
I just upgraded from my old Series 2, which I had previously upgraded about 2 years ago using your TiVo 240080 TiVo Upgrade Kit: (Add one 1 TB hard drive and Advanced Cooling Pak). Now I have two Tivo Premieres. I suppose I will take my old series 2 in to Bestbuy for recycling, but I was just curious if I could save the hard drive for any purpose, such as increasing the capacity in one of the Premieres?
Second question that Tivo support could not help me with, but not a Weaknees question - maybe you know anyway. I would like to connect the second Tivo to my projector using the HDMI cable. I did that and then I also connect audio out to my receiver/amplifier using standard audio cables. When the Tivo booted, the picture showed nicely on the projector until it finished the initial sequence, then the screen went blank. Wondering if this is a HDMI copy protection problem due to the audio cables. Unfortunately there is not a audio out port on my projector. Any other way to fix this? Alternatively, I have to use component cables from Tivo to receiver to projector, which may not be as good a picture (but maybe no difference, I suppose). Thanks
