SD Direct TV Tivo Max HDD size
  • SD Direct TV Tivo Max HDD size
    Howdy,
    I haven't finished reading through all the posts yet, so I'm sorry if this is a frequently answered question.
    What is the max HDD size I can put in a series 2 Hughes Direct tv TiVo?
    Will the image on the drive replacement site work with the big drive?
    I'm a bit of a DIY and have no problem ripping into stuff.
    Dennis
    You can do dual terabyte drives in that unit with the appropriate SATA adapters. That's the largest.
    http://www.weaknees.com/tivo-sata-to-ide-adapter.php
      Michael,
      Thanks. I'm off to get the adapter.
        Not to be too self-serving, but we highly recommend our adapters. They work on these units, where many others don't.
          SATA-PATA unhappiness
          Not working here. Experimentation suggests that the JM20330-based boards do not allow other JM20330-based boards to share the bus. This seems a bit pathological, but follow along:
          I've got the resources of our electronics shop available here, and so I've tried quite a few things.
          The original goal was to take a HDVR2 (6.2) that was given to our family and to stick as much storage as possible into it, which turns out to be two 1TB Seagate Barracuda 7200.12 drives.
          I staged a TiVo test environment on an 80GB IDE, and when I got happy with it, the idea was to use MfsLive to bang it up to 2x1TB. Unfortunately, we've had problems with SATA-PATA translators in the past. Trying several units from the bin did not yield what I would consider to be good results; I started reading, found praise for the JM20330 boards, found a few, tried them, no go. Bought a pair from a recommended seller from eBay (another forum has a thread on this), turned out to be identical to one of the boards we had in stock, still no go. Further reading left me wondering whether or not I wanted any further inventory of dodgy devices, so when pondering whether to buy another recommended device, or just pay retail for the WeaKnees "guaranteed" boards... since I wanted a nice drive bracket anyways, we did that. And ... got yet two more JM20330 boards.
          Spent extensive time trying to figure out how to make them work. Short form: they don't want to coexist. I can plug in the master by itself, that's fine. The slave by itself, that's fine. Both? Various ill stuff happens. I've tried a variety of different 80 and even 40 pin cabling strategies, ordering the primary and the master both ways, etc.
          So here's my boggle. It's all cabled up to the build PC. The PC sees either one or neither drive, kind of randomly but kind of affected by the particulars. If I remove the JM20330 that's configured as master and drop in a SATALink based PATA-SATA adapter, leaving the secondary JM20330 alone, the PC sees everything fine (well, that has yet to be thoroughly tested, but *seems* to see everything fine).
          I'm at a loss. Are two of these JM20330's actually supposed to work together? Does anyone have any ideas?
          Think I'm going to go up and see if the TiVo is happy with the SATALink board, can't remember, it's been a little while now. Maybe I can get the TiVo up and running with one of each.
          ... JG
            We do use two of these boards together in various situations. But we always use them with AV drives - usually WDs. Do you think the drive type may be the issue?
              More info on JM20330 compatibility (or lack thereof)
              Yeah, good theory... while we don't have AV drives, we do have a variety of stuff. I put in some Caviar SE's (WD800JD), and that worked... but after a relatively thorough testing of various drive types, I've come to the conclusion that you probably want to stop certifying these, or at least put in a big huge CAVEATS (Caviats? haha) section. The following data was collected by testing the various listed drives against your SATA JM20330's on an ATA33 cable against the BIOS probe of an HP DC7600 business PC, and the definition of "works" means nothing more than it appeared to probe as expected. In some cases, multiple drives of the same type were not available; these account for some gaps in the table. The data is free to all to use for any purpose, with the understanding that it represents nothing more than what is described above, and there are no warranties of any kind.
              HTML Code:
              <pre>
                      sec     WD800JD HDS250G SB400GB SB1TB   MAXDM9  SAM80G
              pri
              WD800JD         allok   prionly allok   prionly prionly prionly
              HDS250G         prionly -       prionly prionly prionly prionly
              SB400GB         prionly prionly allok   prionly prionly prionly
              SB1TB           allok   prionly allok   prionly hangs   prionly
              MAXDM9`         allok   prionly allok   allok   prionly prionly
              SAM80G          allok   prionly allok   allok   prionly -
              </pre>
              WD800JD = WD Caviar SE WD800JD 80GB
              HDS250G = Hitachi DeskStar HDS722525VLSA80 250GB
              SB400GB = Seagate Barracuda 7200.8 400GB
              SB1TB = Seagate Barracuda 7200.12 1TB
              MAXDM9 = Maxtor DiamondMax Plus 9 80GB SATA/150
              SAM80G = Samsung HD080HJ 80GB SATA
              allok = drives probed successfully (no promises it works though)
              prionly = only the primary drive probed
              hangs = system hung
              So now that I've played Tower of Hanoi for an hour or two with disk drives, I'm left puzzling what to do. The TiVo Community Forums has a list which also suggests the ADSAIDE Adapter by Addonics, which as far as I can tell, is another Taiwanese special, also sold more commonly by Startech as the IDE2SAT, etc. It isn't clear that forking over twenty more bucks for a pair of these is going to fix the problem.
              On the flip side of the coin, I'm not sure that I'm impressed with the WD drives. On the one hand, we have the lower 3-year warranty. On the other hand, we have the WD10EVVS, compromising with an 8MB cache and accomplishing 5.4W busy/2.8W idle power levels, or the WD10EVDS, with a more reasonable 32MB cache but running at 4.9W/4.2W. The prices are okay but someone seems to have biffed on the newer drive's product requirements. I can't readily tell whether or not Data Lifeguard or some other tool can modify the capacity of the WD15EVDS, but given that you can theoretically ramp the block numbers out to 2^31-2, it could provide up to 10% extra space to go that route over the standard 1TB disks.. overall it might be okay to go out and get some EVVS drives, but I hate to throw even more money at this.
              So, a little annoyed and frustrated.
                And ... it still fails
                Well, I decided to try a pair of WD10EVVS drives, which are presumably the WD AV drives you've been using successfully. I will say that it did appear to work better, racking up about an hour of uptime, until it crashed and then GSOD'd, which *also* crashed.
                hdb: dma_intr: status=0x10 { SeekComplete }
                hda: DMA disabled
                hdb: DMA disabled
                hda: re-enabled DMA
                hdb: set_drive_speed_status: status=0x00 { }
                hdb: re-enabled DMA
                ide0: reset: success
                hdb: flush_intr: status=0x10 { SeekComplete }
                hda: DMA disabled
                hdb: DMA disabled
                hda: re-enabled DMA
                hdb: re-enabled DMA
                hdb: recal_intr: status=0x10 { SeekComplete }
                hda: DMA disabled
                hdb: DMA disabled
                hda: re-enabled DMA
                hdb: re-enabled DMA
                hda: DMA disabled
                hdb: DMA disabled
                hda: re-enabled DMA
                hdb: re-enabled DMA
                hda: DMA disabled
                hdb: DMA disabled
                hda: re-enabled DMA
                hdb: re-enabled DMA
                hda: DMA disabled
                hdb: DMA disabled
                hda: re-enabled DMA
                hdb: re-enabled DMA
                hda: DMA disabled
                hdb: DMA disabled
                hda: re-enabled DMA
                hdb: re-enabled DMA
                end_request: I/O error, dev 03:43 (hdb), sector 1822956544
                Tmk Assertion Failure:
                putbuf, line 1506 ()
                Tmk Fatal Error: Thread TmkClipCache2 <230> strayed!
                Paste the following into a shell to get a backtrace...
                bt -t /tvbin/tivoapp <<END_OF_BT
                read 0x2aaa8000 /lib/ld.so.1
                read 0x2ab04000 /lib/libutil.so.1
                read 0x2ab48000 /lib/libdl.so.2
                read 0x2ab8c000 /lib/libpthread.so.0
                read 0x2abe8000 /lib/libm.so.6
                read 0x2acb0000 /lib/libc.so.6
                0x00dca7b0 0x00dd07bc 0x00dd0590 0x00dccad0 0x00dd1f78 0x00e02100 0x00e013ac
                0x013a706c 0x013ce190
                END_OF_BT
                Tmk Fatal Error: Thread TmkClipCache2 <230>: assertion failure
                flushing ide devices: hda hdb
                Restarting system.
                CPU revision is: 00005430
                FPU revision is: 00005410
                Primary instruction cache 32kb, linesize 32 bytes.
                Primary data cache 32kb, linesize 32 bytes.
                Linux version 2.4.20 (build@buildmaster5) (gcc version 3.0) #22 Fri Feb 20 18:19:25 PST 2004
                Determined physical RAM map:
                memory: 04000000 @ 00000000 (usable)
                On node 0 totalpages: 16384
                zone(0): 16384 pages.
                zone(1): 0 pages.
                zone(2): 0 pages.
                Kernel command line: root=/dev/hda7 dsscon=true console=2,115200 upgradesoftware=false
                Monotonic time calibrated: 81.00 counts per usec
                Calibrating delay loop... 161.79 BogoMIPS
                Contiguous region 1: 8388608 bytes @ address 0x80d00000
                Contiguous region 2: 1048576 bytes @ address 0x81500000
                Contiguous region 8: 10485760 bytes @ address 0x81600000
                Contiguous region of 19922944 bytes total reserved at 0x80d00000.
                Memory: 43820k/65536k available (1222k kernel code, 21716k reserved, 81k data, 64k init, 0k highmem)
                Dentry cache hash table entries: 8192 (order: 4, 65536 bytes)
                Inode cache hash table entries: 4096 (order: 3, 32768 bytes)
                Mount-cache hash table entries: 1024 (order: 1, 8192 bytes)
                Buffer-cache hash table entries: 4096 (order: 2, 16384 bytes)
                Page-cache hash table entries: 16384 (order: 4, 65536 bytes)
                Checking for 'wait' instruction... unavailable.
                POSIX conformance testing by UNIFIX
                PCI: Probing PCI hardware
                ttyS00 at iomem 0xb4100100 (irq = 79) is a 16550A
                ttyS00 at port 0xbc010000 (irq = 133) is a unknown
                ttyS00 at iomem 0xb4100140 (irq = 81) is a 16550A
                ttyS00 at iomem 0xb4100120 (irq = 80) is a 16550A
                Linux NET4.0 for Linux 2.4
                Based upon Swansea University Computer Society NET3.039
                Initializing RT netlink socket
                Starting kswapd
                Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled
                ttyS00 at 0xb4100100 (irq = 79) is a 16550A
                ttyS01 at 0xbc010000 (irq = 133) is a unknown
                ttyS02 at 0xb4100140 (irq = 81) is a 16550A
                ttyS03 at 0xb4100120 (irq = 80) is a 16550A
                Uniform Multi-Platform E-IDE driver Revision: 6.31
                ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
                hda: WDC WD10EVVS-63E1B0, ATA DISK drive
                ide0 at 0x400-0x407,0x438 on irq 87
                hda: 1953525168 sectors (1000205 MB) w/8192KiB Cache, CHS=121601/255/63
                Partition check:
                hda: [mac] hda1 hda2 hda3 hda4 hda5 hda6 hda7 hda8 hda9 hda10 hda11 hda12 hda13 hda14 hda15 hda16
                RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
                PPP generic driver version 2.4.2
                PPP Deflate Compression module registered
                NET4: Linux TCP/IP 1.0 for NET4.0
                IP Protocols: ICMP, UDP, TCP
                IP: routing cache hash table of 512 buckets, 4Kbytes
                TCP: Hash tables configured (established 4096 bind 8192)
                ip_conntrack version 2.1 (512 buckets, 4096 max) - 152 bytes per conntrack
                ip_tables: (C) 2000-2002 Netfilter core team
                NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
                VFS: Mounted root (ext2 filesystem) readonly.
                Freeing unused kernel memory: 64k freed
                Starting rc.sysinit
                Running boot Stage A_PreKickstart scripts
                Scanning for configuration files
                Invoking startup scripts for:
                platform 'provo'
                implementation 'Series2'
                implementer 'TiVo'
                Releasing /initrd and clearing ramdisk, if they exist
                warning: can't open /var/mtab: No such file or directory
                umount: /initrd: not mounted
                Activating swap partitions
                Adding Swap: 2097144k swap-space (priority -1)
                Loading core system drivers
                Parallel modem driver loaded, 1 ports starting at /dev/ttyS1
                Loading ircatch
                Found rev 'F' Si2433 modem on /dev/cua1
                Checking for Kickstart panic signal
                Running boot Stage B_PostKickstart scripts
                Cleanup /dev/hda9 pass 1
                ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda9 is mounted.
                /dev/hda9 was not cleanly unmounted, check forced.
                Inode 2073, i_blocks wrong 16 (counted=4). Set i_blocks to counted? yes
                Inode 2071, i_blocks wrong 1138 (counted=1126). Set i_blocks to counted? yes
                Inode 2069, i_blocks wrong 94 (counted=86). Set i_blocks to counted? yes
                Inode 2064, i_blocks wrong 1852 (counted=1844). Set i_blocks to counted? yes
                Inode 2068, i_blocks wrong 172 (counted=166). Set i_blocks to counted? yes
                Inode 2080, i_blocks wrong 134 (counted=124). Set i_blocks to counted? yes
                Fix summary information? yes
                /dev/hda9: 654/32768 files (7.5% non-contiguous), 9294/131072 blocks
                Cleanup /dev/hda9 pass 2
                /dev/hda9: clean, 654/32768 files, 9294/131072 blocks
                /dev/hda9 is clean after pass 2
                Mounting /var
                /dev/hda9 on /var type ext2 (rw)
                Cleaning up files in /var
                Checking space in /var
                Mounting initial environment
                Starting logging daemons
                Found Silicon Labs "Si2433" modem, rev F, skipping modem patch
                Scanning for phase1 repair scripts
                Running boot Stage C_MediaInitialization scripts
                Loading input section drivers
                cobra module was successfully installed, LNBPA 0x10 LNBPB 0x16
                Loading output section drivers
                Splash the screen
                Running boot Stage D_PreMfs scripts
                Remote control is TIVO
                MFS partition on /dev/hda10
                Loading Provo dssapp
                Look for debug board
                /tvbin/dssapp: DSS Interface Version 1.24, compiled on Nov 12 2004
                Loading irblast
                Loading ideturbo
                Loading fan
                Loading therm
                Loading TvBus router
                Updating system clock
                Time set to: Tue Jun 30 22:31:33 2009
                Enabling local route
                Setting TCP keepalive parameters
                Checking for additional disk
                Start fan control
                First temperature parameters set:
                Terminal temp: 71
                Critical temp: 62
                Logging temp: 60
                Target temp: 50
                Lowest fan speed: 7
                /tvbin/fancontrol is running in the background.
                Starting TvLauncher
                PokeFirewallPort: Poking hole through firewall at port 2191, protocol tcp
                Waiting for launcher to start.
                Launcher is running.
                Illegal read at 00000008
                do_page_fault #2: sending signal 11 to mfsd(89)
                $0 : 00000000 80180000 00000000 00000000 00000000 7fff66e0 00000042 00000000
                $8 : 00009400 00009400 00000000 0000002c 00000000 00000284 00002867 80151b64
                $16: 7fff66d8 100b3a38 7fff6720 100a4858 100b39e8 00000000 100a4858 00000001
                $24: ba2e8ba3 2ab9029c 1006d910 7fff66a8 01499f78 012f4f9c
                Hi : 00000000
                Lo : 00000000
                epc : 012f4fac Not tainted
                Status: 80019413
                Cause : 00000008
                8001e9fc 8001eac0 80022bb4 80022d74 80024db8 012f4fac
                012f4fac 012df7f0 012de4ec 012e2a44 012e3d24 012cdcbc 012ce3fc 012ea3a0
                01384d20 0138518c 012ea99c 00612bf8 00403090 2acc13fc
                Tmk Fatal Error: Thread mfsd <89> strayed!
                pc 0x12f4fac status 0x80019413 cause 0x000008 bva 0x81dbfdd0 hi 00000000 lo 00000000
                R00 0x00000000 R01 0x80180000 R02 0x00000000 R03 0x00000000
                R04 0x00000000 R05 0x7fff66e0 R06 0x00000042 R07 0x00000000
                R08 0x00009400 R09 0x00009400 R10 0x00000000 R11 0x0000002c
                R12 0x00000000 R13 0x00000284 R14 0x00002867 R15 0x80151b64
                R16 0x7fff66d8 R17 0x100b3a38 R18 0x7fff6720 R19 0x100a4858
                R20 0x100b39e8 R21 0x00000000 R22 0x100a4858 R23 0x00000001
                R24 0xba2e8ba3 R25 0x2ab9029c R26 0x7fff6464 R27 0x00000000
                R28 0x1006d910 R29 0x7fff66a8 R30 0x01499f78 R31 0x012f4f9c
                0x012f4fac 0x012df7f0 0x012de4ec 0x012e2a44 0x012e3d24 0x012cdcbc 0x012ce3fc
                0x012ea3a0 0x01384d20 0x0138518c 0x012ea99c 0x00612bf8 0x00403090 0x2acc13fc
                END_OF_BT
                Tmk Fatal Error: Thread mfsd <89>: unexpected signal 11
                Restarting system.
                zone(1): 0 pages.
                zone(2): 0 pages.
                Starting kswapd
                hdb: probing with STATUS(0x50) instead of ALTSTATUS(0x10)
                hdb: probing with STATUS(0x11) instead of ALTSTATUS(0x51)
                Partition check:
                Starting rc.sysinit
                platform 'provo'
                implementer 'TiVo'
                Loading ircatch
                Inode 2061, i_blocks wrong 942 (counted=930). Set i_blocks to counted? yes
                Inode 2068, i_blocks wrong 182 (counted=168). Set i_blocks to counted? yes
                /dev/hda9: 113/32768 files (15.9% non-contiguous), 7619/131072 blocks
                /dev/hda9: clean, 113/32768 files, 7619/131072 blocks
                Mounting /var
                Splash the screen
                Loading irblast
                Loading ideturbo
                Loading fan
                Loading therm
                Time set to: Tue Jun 30 22:32:46 2009
                Start fan control
                Terminal temp: 71
                Critical temp: 62
                Logging temp: 60
                Target temp: 50
                Lowest fan speed: 7
                Starting TvLauncher
                $8 : 00009400 00009400 00000000 0000002c 00000000 00000288 00002881 80151b64
                Hi : 00000000
                Lo : 00000000
                Status: 80019413
                Cause : 00000008
                R12 0x00000000 R13 0x00000288 R14 0x00002881 R15 0x80151b64
                END_OF_BT
                Restarting system.
                zone(1): 0 pages.
                zone(2): 0 pages.
                Starting kswapd
                hdb: probing with STATUS(0x10) instead of ALTSTATUS(0x50)
                hdb: WDC WD10EVVS-6000, ATA DISK drive
                hdb: set_drive_speed_status: status=0x90 { Busy }
                hdb: task_no_data_intr: status=0x10 { SeekComplete }
                hdb: 1953525168 sectors (1000205 MB) w/8192KiB Cache, CHS=121601/255/63
                Partition check:
                hdb: [mac] hdb1 hdb2 hdb3 hdb4 hdb5 hdb6
                Starting rc.sysinit
                platform 'provo'
                implementer 'TiVo'
                Loading ircatch
                Inode 2061, i_blocks wrong 960 (counted=956). Set i_blocks to counted? yes
                Inode 2069, i_blocks wrong 106 (counted=94). Set i_blocks to counted? yes
                Inode 2068, i_blocks wrong 184 (counted=172). Set i_blocks to counted? yes
                /dev/hda9: 113/32768 files (15.9% non-contiguous), 7636/131072 blocks
                /dev/hda9: clean, 113/32768 files, 7636/131072 blocks
                Mounting /var
                Splash the screen
                Loading irblast
                Loading ideturbo
                Loading fan
                Loading therm
                Time set to: Tue Jun 30 22:33:58 2009
                Start fan control
                Terminal temp: 71
                Critical temp: 62
                Logging temp: 60
                Target temp: 50
                Lowest fan speed: 7
                Starting TvLauncher
                hda: DMA disabled
                hdb: DMA disabled
                hda: re-enabled DMA
                hdb: re-enabled DMA
                hda: DMA disabled
                hdb: DMA disabled
                hda: re-enabled DMA
                hdb: re-enabled DMA
                ide0: reset: master: error (0x00?)
                end_request: I/O error, dev 03:44 (hdb), sector 1
                Filesystem assert: ! err at fszone.C line 718 in TwStatus FsZone::Sync()
                Filesystem flagged as inconsistent!
                Tmk Assertion Failure: ! err
                TwStatus FsZone::Sync(), line 718 (fszone.C)
                0x012e4f08 0x012e8f98 0x012d659c 0x012e17bc 0x012deaf8 0x012e2a44 0x012e3d24
                0x012cdcbc 0x012ce3fc 0x012ea3a0 0x01384d20 0x0138518c 0x012ea99c 0x00612bf8
                END_OF_BT
                Tmk Fatal Error: Thread mfsd <89>: assertion failure
                Restarting system.
                zone(1): 0 pages.
                zone(2): 0 pages.
                Starting kswapd
                hdb: WDC Q10EVVS-63E1B0, ATA DISK drive
                hdb: set_drive_speed_status: status=0xd0 { Busy }
                Partition check:
                Starting rc.sysinit
                platform 'provo'
                implementer 'TiVo'
                Loading ircatch
                Inode 2061, i_blocks wrong 996 (counted=982). Set i_blocks to counted? yes
                Inode 2069, i_blocks wrong 110 (counted=96). Set i_blocks to counted? yes
                Inode 2068, i_blocks wrong 188 (counted=174). Set i_blocks to counted? yes
                /dev/hda9: 113/32768 files (15.9% non-contiguous), 7651/131072 blocks
                /dev/hda9: clean, 113/32768 files, 7651/131072 blocks
                Mounting /var
                Splash the screen
                Loading irblast
                Loading ideturbo
                Loading fan
                Loading therm
                Time set to: Tue Jun 30 22:35:15 2009
                Start fan control
                Terminal temp: 71
                Critical temp: 62
                Logging temp: 60
                Target temp: 50
                Lowest fan speed: 7
                Starting TvLauncher
                Filesystem is inconsistent - cannot mount!
                hda: DMA disabled
                hdb: DMA disabled
                hda: re-enabled DMA
                hdb: re-enabled DMA
                fsfix: mounted MFS volume, starting consistency checks.
                I-Nodes:
                I-Node table size is 524288 entries for 500000 active nodes max.
                FsId high-water mark is 0x24266
                Pass 1 - scan and analyze
                reconstructing zone buddymaps
                synchronizing...
                volume marked as needing database cleanup
                scanned 70787 files, covering 18774 extents
                210824 application pages in use
                113678336 media pages in use
                Inode table collision details
                0 hash collisions in node table.
                Allocation Details
                53396/70429 application inline files, 75.81%
                46.58% wasted space (75 bytes) in normal application region
                43.85% wasted space (75 bytes) in inlined application region
                358 media files
                3.24% wasted space (75 bytes) in media region
                Fragmentation:
                average extents/file is 0.26
                worst extents/file is 10
                expected extents/file (approx) is 3
                Application region:
                zone contains 523072 pages: 183912 allocated; 339160 free
                zone contains 65384 extents of 8 pages each
                inode allocations match allocated page count
                buddy-map is internally consistent, 339160 pages marked free
                zone contains 524176 pages: 26912 allocated; 497264 free
                zone contains 65522 extents of 8 pages each
                buddy-map is internally consistent, 497264 pages marked free
                Media region:
                zone contains 33099776 pages: 33095680 allocated; 4096 free
                zone contains 16162 extents of 2048 pages each
                buddy-map is internally consistent, 4096 pages marked free
                zone contains 44161024 pages: 44111872 allocated; 49152 free
                zone contains 21563 extents of 2048 pages each
                buddy-map is internally consistent, 49152 pages marked free
                zone contains 1869152256 pages: 36470784 allocated; 1832681472 free
                zone contains 57042 extents of 32768 pages each
                buddy-map is internally consistent, 1832681472 pages marked free
                zone contains 1869152256 pages: 0 allocated; 1869152256 free
                buddy-map is internally consistent, 1869152256 pages marked free
                zone contains 84344832 pages: 0 allocated; 84344832 free
                zone contains 2574 extents of 32768 pages each
                buddy-map is internally consistent, 84344832 pages marked free
                fsfix: 0 fatal errors, 0 warnings.
                mfscheck scan begins
                hda: DMA disabled
                hdb: DMA disabled
                hda: re-enabled DMA
                hdb: re-enabled DMA
                hda: DMA disabled
                hdb: DMA disabled
                hda: re-enabled DMA
                hdb: re-enabled DMA
                end_request: I/O error, dev 03:42 (hdb), sector 1
                Tmk Fatal Error: Thread mfscheck <95> strayed!
                0x012e4f08 0x012e8f98 0x012d659c 0x012e17bc 0x012f1740 0x012f1444 0x012f281c
                0x012d7dbc 0x012b34bc 0x00612ce8 0x00403090 0x2acc13fc
                END_OF_BT
                Tmk Fatal Error: Thread mfscheck <95>: assertion failure
                Restarting system.
                Now it's acting like the B drive is not entirely there, stuck in a crash/reboot loop, so I'm thinking maybe it's been spun down. Getting varying stuff like
                hdb: probing with STATUS(0x00) instead of ALTSTATUS(0x50)
                hdb: probing with STATUS(0x00) instead of ALTSTATUS(0x58)
                hdb: WDC WD10EVVS-63E1B0, ATAPI UNKNOWN (type 2) drive
                So, overall, I'm still working on this, but as of now, it isn't looking very promising.
                  This problem with the SATA-IDE adapters has been resolved, see http://www.wkforums.com/forums/showthread.php?t=3823 for the details.
