Series 3 HD Tivo rebooting spontaneously
  • Series 3 HD Tivo rebooting spontaneously
    i have a WK series 3 with 100 hours. it has been rebooting on it's own. part way through a show it will start to stutter, freeze and then reboot.
    the unit is probably 1.5 years old or more.
    is a hard disk failing? what should i do? this has been going on for several weeks. no better no worse.
    Carl
    That's almost definitely a bad drive, but it could be a bad CableCARD, too. Likely, though, if you haven't changed CableCARDs recently, it's a bad drive.
    Does it have an extended warranty? If so, just email us. If not, replacement drives are here:
    http://www.weaknees.com/s325.php
      we recently moved and it did start to happen after the move. i don't remember exactly if it was immediately after the move or later. it was at least close to the time we moved. i also had trouble with the cable cards and they had to come out a couple of times until i was receiving all the channels.
      how do i check to see if it is the cable cards?
      Carl
        Try using it without the cards for a bit and see if the problem ceases.
          what happens when i take out the cable cards? won't i lose all ability to record and then i won't know if the cable cards are causing the problem?
          Carl
            You'll lose the ability to record encrypted shows, but not "basic" cable, and not any HD from an antenna.
