I have a Series 2 540040 modified to about 230 hours with a Weaknees add on drive. I just moved a couple of miles away and upon reconnecting this TiVo via coax it doesn't appear to be getting any input signal from my cable. I verified there was no change to settings regarding input. I get the message listed above in the title of this thread. It doesn't appear to be signal strength related because the same connection works on my my Series 3. Outputs are good as it plays previous recorded content. Any ideas?
Searching for signal on: Basic Cable In
Everything is the same
Connected to Cable/Antenna RF IN just as before. Straight in cable, no box just as before. First try at rectifying problem was to repeat guided setup. Changed nothing but ZIP code. Connected a third TiVo in the house to these inputs and was succesful. Reconnected original TiVo still no signal in. System Information page shows - Program Source: Cable without box - Source Input: Coax RF In.
you have no warranty on the unit once you open it. however, you are not looking for warranty work.
if you send the unit back with our drive, you will not get the upgrade drive back, so you might want to return the unit to its factory specifications before sending it back.
