I just received my new replacement HD (70 hr) capacity for my Series 2 Directtv DVR. I'm installing it into a DVR which I had previously upgraded to a 2 drive configuration. I installed the new HD in place of the original HD (closest to the left when viewed from the front panel). I installed a jumper to the Master position on the new drive. It set-up just fine, but now only shows 66 hours recording capacity. My second HD is 120GB and prior to drive replacement, the DVR showed capacity equating to both HD's working. Did I make a mistake by installing the jumper?
Install config question
Second Drive
If I recall correctly, when I installed the B drive, it was a raw drive that I purchased and I used your bracket. Is that likely or would I have purchased the drive from you too? If so, can I just reformat the drive in one of my PC's? If I got the drive from you originally, can you just reformat the b drive without my taking the DVR out of service? The two drives were never together until I installed the B.
Our drive kits aren't "raw" - they're formatted specifically to make the upgrade work. If you want to try it, info is here:
http://tivo.upgrade-instructions.comBeen here a long time . . .
Sure - but we also need your A drive back here. Larger-than-factory A drives need to be in our PC at the same time as the older B drive. Email us with your order number and we can figure out pricing:
info@weaknees.comBeen here a long time . . .
