DVR40 stopped working when additional drive installed
  • DVR40 stopped working when additional drive installed
    I bought an add a drive kit from weaKnees and followed directions and now I cannot get either drive to work. When powered on I get "welcome. powering up" and the unit stops. I've tried both hard drives seperately , making sure that the jumpers were set correctly, but still only get to the "welcome" screen.
    Any ideas?
    OK - first, an "add" drive kit will only work in conjunction with an existing factory drive. It has no OS on it - just the right partitioning information.
    Next, did you original drive work properly before this?
      DVR stoped working
      The new (second) hard drive was from another directv tivo that I replaced with a larger (300 gb) purchased from weaKnees. The 300 GB works perfectly. I figured that I could take the smaller drive and add it to my existing second D-Tivo to increase its' capacity.
        Both drives worked in thier respective machines, but now neither works in the second machine
          What you are trying to do simply won't work. Once you add a drive to a TiVo, the two become inseparable...a married pair. Sounds like you are trying to pull 1/2 of the pair out and stick into another TiVo...that won't work unless the drive is reprogrammed for the new TiVo.
            I guess I'll order a replacement hard drive. I still have the add a hard drive kit. Anybody want to buy it?
